How to locate Vin Number on 360 sedan
sriwelaratna
I acquired a Subaru 360 sedan a few months ago and joind the club. Can someoen help me to locate the vin number on the car which I hope will lead me to identify the year of make? The engine is claimed to be running, the gas tank has holes in it and there are lots of rust areas to be sorted out. Would someone have a gas tank for sale? Can someone aso let me know if it is possible to buy the windscreen rubber gasket and the rubber for the two side windows that open?
Re: How to locate Vin Number on 360 sedan
The VIN plate should be under the hood, under the spare tire. It is a very flimsy aluminum plate glued to the firewall. Rubber for the side windows is not available, have to locate good used pieces, if you can. It is made of unobtanium and very hard to find. The windshield rubber is not available in the original form, aftermarket is available, check in the posts, someone in the club has it... Good luck with the car
Was 2 360's
Now 4
Now 4
If you can't find it from this info, E-MAIL ME so I can return a photo to you by e-mail of the page from the owner's manual shat shows the location of the sedan VIN.
If you happen to have a truck or van instead of a sedan, I can show you the location of that also.
Ed Parsil, Tucson AZ (see ROSTER for my e-mail address)
"unobtanium" They sure used a lot of that stuff as near as I can tell. Possibly main ingredient.dmkberger wrote: It is made of unobtanium and very hard to find. The windshield rubber is not available in the original form, aftermarket is available, check in the posts, someone in the club has it... Good luck with the car
Chassis Number location on my sedan:
sriwelaratna
Thanks for the helpful comments and the unhelpful but very funny one with the name of the element that had eluded me all this time. In two days time I will get an opprtunity to check out the vin number. I will post my findings.
There is a thread where Ed is collecting all known VIN's, post up in there, or email him so he can add you.
Can anyone enlighten Steve on the above points? I think he is asking about van and or truck Vin locations, but I am not entirely sure. My knowledge of Vin location(s) is confined to sedans only - Sorry!Velecasa wrote:Hibooks1 wrote:Chassis Number location on my sedan:
I saw a post that u posted a pic of a spot where vin can be found
obviously the plate ay top in front trunk
But where is that pics
How many spot are there where vin is avail ?
Help will be greatly appreciated
He mentioned that he acquired a sedan a few months ago.. so I'd imagine that your info was somewhat helpful.
VIN stamped onto frame in the sedan front trunk:
Very helpful need for sedan thanks
Is that spot and plate above jack / brake fluid receptacle only spots or is there more ?
I sucks being computer stupid ! Lol
besides the stamp, there is an aluminum plate with it as well. I think someone posted the location of that earlier.Is that spot and plate above jack / brake fluid receptacle only spots or is there more ?
My reply on this disappeared too.
Remove the spare tire, look at the metal
"crossmember" below where the tire was,
wash it if necessary
THERE IS THE VIN, STAMPED IN THE METAL;
Is that the small aluminium "tag" that is usually found attached to the jack holder bracket? If so, I don't think it is the same number as the VIN, at least not in my case anyway.Micro Image wrote:besides the stamp, there is an aluminum plate with it as well. I think someone posted the location of that earlier.Is that spot and plate above jack / brake fluid receptacle only spots or is there more ?
It's not the VIN. My sedan had it too.
Gamestermike89
So if someone says they have a "matching numbers" subaru 360. Are they full of it? Or is the number actualy somewhere on the chassis and engine somewhere?
1969 Subaru 360 sedan
1982 Cadillac Fleetwood brougham.
1999 Toyota Camry (every day beater)
"matching numbers" means nothing on a 360.
The VIN for a sedan is K111L-(4 or 5 digits)
The only thing that matches it is the title
Engine # is not important and is nothing like the VIN
"matching numbers" is in a class with "very rare"
and "less than 100 imported"
- and "ran when parked"
Gamestermike89
Thats sad. I was hoping to match thoes up.
