Finally took the plunge and bought a 1970 Subaru Truck. Had been somewhat interested in 360's from afar when I had several Honda 600's, (I hated the fact that the Honda 600 cranks were not serviceable), but was never able to find a decent 360..... I also did not realize the wealth of information here and after reading thru many posts see that there seems to be a true comradery which is a breath of fresh air!
Thank you all for this site!
For the most part The Truck is fairly rust free other than some surface rust and a rough spot near the drivers side. I was able to get the motor running after some tinkering with the carburetor/gaskets and timing! Brakes need R/R but already reading thru the posts and the grease gun trick saved me much time, (thank you!). I did make one newbie mistake and took a blow torch to the cylinders. While it was not much heat and I kept the tourch moving I am worried I may have warped one of the cylinders, (fingers crossed).
Thank you all for the site and see you on the Message Threads!
Here is a picture of the Truck.
BR,
Rick
